HELP!!! 2.4Ghz TX/RX
Hello peeps,
I need your help. I have a mini summit that I am having trouble getting to turn/steering issue.
When I bought it (used) it would only turn left with the tx wheel, then, I reset the receiver to the default settings and now it would turn left and right but the turn is very minimal. I have tried to adjust the steering end point adjustment with no success. Do you know what else should I try? I am having a bad receiver/tx/servo? Any suggestions will be greatly appreciated. If I can't fix this issue I will just sell it.
yes, servo is centered
Yes, servo bind at full lock
Don't know the travel set at
sorry not very knowledgeable when it comes to radios. it may just be easier to get another radio and receiver. thanks
