Fly Sky GTB3 ?
Old 02-07-2012 | 07:01 PM
Default Fly Sky GTB3 ?
I have a FS GTB3 and when I pull the trigger it goes backward, does anyone know how to make it work so when I pull the trigger it goes forward?
Thanks Dan
daaska11 is offline
Old 02-07-2012 | 07:10 PM
pettyeagles's Avatar
You will need to reverse the throttle channel.
pettyeagles is offline
Old 02-08-2012 | 05:52 AM
Do you know how to do that?
daaska11 is offline
Old 02-08-2012 | 11:25 AM
1. Turn radio on.
2. Push large silver dial/button on right of top.
3. Rotate same until "REV" is illuminated (top of screen, second from right).
4. Push the dial/button again. "1" should start flashing. This is your steer channel.
5. Turn dial/button one notch right. "2" should be flashing. This is your throttle channel.
6. Push button labeled 'END' (no one said this would make sense....). 'NOR' should be flashing.
7. Turn dial/button one notch. 'NOR' turns to 'REV'. (=REVerse, see?)
8. Push dial/button again.
9. Drive fast, take chances.
porterdog is offline
Old 02-08-2012 | 01:48 PM
or did u put the wires that got to your motor in wrong because ive done that before so it went backwards instead of foward
chancejeff is offline
Old 02-08-2012 | 06:47 PM
Thanks I actually had to do what you said and reversed the throttle.
I did try the reversing wires first but it was the throttle thanks and great directions
Dan
daaska11 is offline
Old 02-10-2012 | 09:39 AM
It helped that I had my radio right in front of me when you asked the question!
