spektrum remote questions.
Hey guys, i just bought the spektrum DX3E. I was planning on also buying the associated b4.1 rtr. I was just wondering, if i buy another sr300 reciever, will i be able to run the same remote with both cars? like i have a slash right now, and im putting the included sr300 in that. The associated one is so bad that i am willing to buy another reciever if i works. any help appreciated!!!!
elecRC23 :) |
The DX3E is a single model radio. It is intended to be used with one vehicle only. Multiple model radios are: DX3R, DX3C, DX3S, DX2S
You can use the same transmitter, you just need to bind each time you change cars
Cheers |
okay cool thanks. so i just have to buy a new reciever and i can just bind it whenever i want to switch?
Bind it, and probably reset end points and trims. To me, it would be a big enough pain that I would look at a new radio. But if funds are that tight, then yes you can do it.
A new radio like one of the ones I mentioned above can be used with the receivers you have. They just have additional slots in memory for each model that maintains trims and end point settings. |
Also some of the Spektrem transmitters can be bought just by them selfs, I.E. no RX or servos. I know the DX3S is available that way.
Bob Oaks |
| All times are GMT -7. It is currently 01:12 PM. |
