Venom Pro Charger Plus
I will be charging 2s 5000mah lipos what do you guys think about this venom Pro Charger Plus
$129.99 tower hobbies. any good? for the anything better same price? |
Way overpriced. That is a ~$35 charger at HobbyKing or HobbyPartz. Will not even charge your packs at 2c. If you are looking to order from Tower the following charger is more capable and much cheaper:
http://www3.towerhobbies.com/cgi-bin...?&I=LXAGTS&P=7 Of course if you are looking for higher end chargers, Hyperion, FMA and the Junsi chargers are good picks. Also, if you want a relatively cheap duo charger the Hitec Duo unit is a good deal with the best warranty support in the business. |
Originally Posted by kcobra
(Post 10242814)
| All times are GMT -7. It is currently 12:06 PM. |
