Paraboard question
Old 01-27-2012 | 05:36 PM
Default Paraboard question
Getting ready to try my Icharger 206 out for the first time. What setting do I charge at using this board. Say I charge only 3s packs. Do the settings change based on number of packs. Im charging nano techs that claim a 8c charge. I charger only goes to 20 amp. I have 5000 mah packs. So I plug my packs into board and charge on 3s 20amp? Does it matter if its 2 packs or 6 for the settings?
ffr3247r is offline
Old 01-27-2012 | 05:40 PM
Add the capacities of your packs to calculate the charge rate
Single 5000mah sized pack
1c = 5 amps
2c = 10 amps
4c = 20 amps
2 x 5000mah sized packs in parallel
1c = 10 amps
2c = 20 amps
5000mah and 4000mah in parallel
1c = 9 amps
2c = 18 amps
Cheers
crusey_aus is offline
Old 01-28-2012 | 11:10 AM
Note that all the lipos connected have to be same cell count....maybe take a min and read to help understand what you're trying to do -
http://www.rchelicopterfun.com/paral...-charging.html
Duster_360 is offline
