Need Advice!
Ok i just bought a TT01D Type e Kit.
Update!!: Got some nice parts for really cheap! FlySky FS-GT3B Digital 79P-GT3B-CarRadio-LCD 1 39.95 3ch 2.4ghz TX & RX LCD Transmitter & Receiver Dynam Supermate DC6 DC 60P-DYC-1004 1 23.70 Multi 1-6S LiPo Charger/Discharger/Balancer HobbyWing EZRUN Brushless 07E-EZRUN-Combo-B2 1 70.60 System Combo B2 w/ 35A ESC & 9T@4300KV 3650M Brushless Motor for 1/12,1/10 on-road racing for experienced drivers GENS ACE 5000mAh 40C 7.4V 98P-40C-5000-2S1P-HardCase-Direct 2 33.42 Hardcase Lipo Battery Pack Roar Approved (Direct Version) Tell what you think im goin to use the stock motor till i get used to the car then ill put in the brushless |
Check out hobbypartz.com and hobbyking.com, they have great deals on some good items. I recommend you pick up very basic components for your first car. Later down the road you will have a better understanding of what you want or need from the components, and you wont have so much invested that it will hurt to replace them with better stuff. If you try to buy fancy stuff now it may do more harm than good.
I suggest the Flysky GT3 radio, very basic and reliable, but also very cheap. I also recommend starting with a couple of cheap Nimh packs and a basic charger for your car. Lipos are just as cheap and offer better performance, but your car is not equipped to handle them and they do require that you learn alot about them before use for safety reasons. |
Originally Posted by burnineyes
(Post 10230726)
what about these batteries guys?
GENS ACE 4000mah 2S1P 7.4V 25C Hard Case Lipo Battery ROAR Racing Approved (Direct) |
got some nice goodies check the original post for the parts an tell me what you think!
Looks nice, it should give you good performance for a long time. Just be careful running the lipo without a voltage cutoff, which is built into the brushless system but not the stock system.
(Post 10234002)
I would consider a voltage cutoff mandatory with LiPos as they can go up in flames! Most ESCs support this now at all price levels. Also, I consider a balancing charger mandatory as well. Your batteries will last longer with fewer issues. They don't cost that much more either. Consider it cheap insurance as your house/car are at stake and anywhere else you are charging your batteries. Use a LiPo bag too. Most tracks require them. :cool:
I see this is an old thread... I hope you followed this advice before now! |
| All times are GMT -7. It is currently 09:21 AM. |
