-   -   servo voltage and reliability in the long term (https://www.rctech.net/forum/radio-electronics/588902-servo-voltage-reliability-long-term.html)
Pulse_ 01-18-2012 12:53 AM
Hello,
I just bought a savox 1258tg which can handle up to 7,4v. Will it hold up better in the long term if I use it with a lower voltage or is it completely safe to push it up to 7,4v? I have a 10a castle bec and a RX8 speedo
crusey_aus 01-18-2012 12:58 AM
If the servo manufacturer quotes 7.4v then its safe to assume it will handle it without effecting its lifespan
Lowering the voltage will lower the speed and torque
Cheers
etivac13 01-18-2012 12:59 AM
though it can handle 7.4V..the 1258 is rated at 6V max(specs).... just connect it to your rx8..it has a 6V/5A BEC.. it can handle your savox...
WindDrake 01-18-2012 01:11 PM
Agreed. 7.4v Tolerant is not the same as 7.4v Rated.
