-   -   KO/Castle binding issue (https://www.rctech.net/forum/radio-electronics/585948-ko-castle-binding-issue.html)
Jeauxkor 01-10-2012 01:14 AM
I have a Ko Propo EX-1 UR that will not calibrate to my castle mmp esc. The weird thing is, I have the exact same set up in two cars. The radio calibrates with no issue to one car but not the other. Out of curiosity I tried a Traxxas radio/reciever and the problem esc calibrated to that radio with no issue. What would make that particular esc "not like" the KO radio? I am stumped. :confused:
Jeauxkor 01-10-2012 01:16 AM
This is for my girlfriends cars by the way. I have changed brands and wanted to hook her up with something better than a stock 2.4 system so I handed down my KO. Not a bad hand me down if you ask me. LOL
crusey_aus 01-10-2012 01:26 AM
Does it actually enter calibration mode ?
Is your throttle trim centered and are your throttle and brake EPA's (Travel) set at 100% before trying to calibrate ?
Check the software version that is running in the ESC, you may need to update or rollback
Cheers
Jeauxkor 01-10-2012 01:44 AM
Yes, it enters calibration mode. My epa's are set correctly. It accepts forward but stops at that point. I think that esc is older than the other. How do i update it? Castle link?
crusey_aus 01-10-2012 02:01 AM
You will need the usb adapter and computer software
Cheers
Jeauxkor 01-10-2012 06:57 AM
You sir were correct. As it turns out, that particular esc had the oldest possible version software on it. Updated it and it worked like a charm. Thanks bro!
