HELP - Futaba 3PK
Have Futaba 3PK with PK-FSM2.4G and R603FS rx
connect servo to ch1
connect esc to ch2
turn on TX, then turn on car
The fan on the esc then starts to fluctuate (faster then slower) and the LED on the RX flash red then green (repeating) when LED is flashing the esc fan also slows down.
Initially servo works fine, then servo action becomes irregular and LED flashes red/green again
apoligies it is really hard to explain.
Have tried with new servo (hobbyking) same issues.
Disconnect servo - issue stops
does anyone have any ideas what i am doing wrong?
cheers
connect esc to ch2
cheers
thanks for the reply, have only got non digital servo's to test with (have ordered digital one)
Set mode to PPM -
Reset ESC to default settings (running in blinky mode)
Turn on TX, then turn on car
Steer left then right - RX flashes green then red - steering not responsive
Replaced servo with new one - identical issue.
Am at a bit of a loss what i have done wrong with this one
Your settings look correct for the transmitter therefore it appears that your servo is drawing too much power and causing the voltage to drop to the receiver. Try adding a "glitchbuster" capacitor to the receiver. I have had to do that with some of the more powerful digital servos. Also check that your steering is not binding anywhere causing the additional draw in power and that the end points are set so that you are not binding the servo at the far end of the travel.
Tried 3 new out of the box Hobbyking HK15288A servo's all caused the same issues.
Borrowed a metal gear servo - problem resolved, also pulled an old futuba servo out of my boys car - problem also resolved.
Looks like wont be using the Hobbyking servo's no more
Appreciate your assistance, will also chase up the glitchbuster capacitor
