Savox digital Servo is suddenly stiff
Got a out of warranty Savox Digital Servo used for rc Drifting. After Transfering it to my new Kit with the same electronics suddenly my .07 sec. speed went down to Cheap analog Speed .3 sec(estimated)
I remembered that when no electric current is passing, my servo is limp and could easily turn the horn. But now it has resistance its like turning a wound up toy .
What seems to be the problem, is there such thing as binding of the Gears inside?
What to do?
What to do?
What to do?
What to do?
I would first remove the servo from the car and first turn your front wheels back and forth by hand using the horn that was attached to the servo and doing so from the position where the servo was mounted. If there's no issue there, plug your servo into the receiver but outside of the car and test it w/o a load. One of those two should isolate your issue.
Sorry for the confusion, But I did it detached from the steering assembly its way slower than before. I am sure there is no binding on the steering.
and when turned off(power). It is like a analog servo resistance you feel the gears moving inside .Where as a digital is pretty limp when done with fingers twisting of the horn with practically no resistance at all. My servo used to be like the later .
Wonder why
Wonder why
Normally when the my stiffen up they are about to go dead.
