M11 upgrade, which module/receiver? >
Old 12-04-2011 | 08:23 PM
Default M11 upgrade, which module/receiver?
Just like title says im upgrading to 2.4.. which spektrum module and receiver works with it?
Would the sm1000 module and sr300 receiver work? Or what is recommended?
charlesandstuff is offline
Old 12-05-2011 | 08:13 PM
td-civ's Avatar
both spektrum moduels work on it and any dsm1 spektrum rx will work
td-civ is offline
Old 12-14-2011 | 01:07 AM
I run the M11 with the SM1000 module. No problems except for that the module plastic is really crappy.
Do the internal antenna mod and don't look back.
ChrisH02 is offline
Old 12-18-2011 | 11:25 AM
So with the sm1000 modules there aren't any that are for a particular brand? I was looking at a sm1000 module and he said it was for like say futaba. But I have an airtronics.. so does that make a difference or are they compatable with a lot of different brands?
Old 12-19-2011 | 10:38 PM
They have the module for Sanwa/Airtronics M8/M11. That's the one you should be getting. I used to run the M8 with the Spektrum module and they work fine
http://www.spektrumrc.com/Products/D...ProdId=SPM1012. This is the 1 you should be getting.
You can also try looking at these, but I never used them so I don't know
http://radiopost.com/products/detail.aspx?cat=102&id=19
dashstryk3 is offline
