DuraTrax IntelliPeak ICE DC Competition Charger
#1564
rotary knob on mine is really weird u gotta push it multiple times b4 it works....any way of fixin it???
cheers
wog
cheers
wog
#1565
the charge leads are too short for my application. if i extend them to about twice their stock length, will it affect the voltage readout, peak detect circuitry, and other functions of the charger? thanks in advance for any info
#1566
It should effect the voltage reading only while current is flowing, but may not interfere with anything at all. Most of the chargeing leads are much oversized to begin with and if you were doing low voltage and/or high current (single cells) then the leads could be made heavier. For normal chargeing using same gage wires is probably going to be just fine.
#1567
i've extended them to 1 foot for each lead, and have not seen any differences noticible on my end... 1 foot is more than enough.
what also works great (and i found these at my local electronics store..) are the right angle plugs. makes it easier for the plugs to come toward the front:
note this is just an image for illustrative purposes, i used a much heavy duty one.. this one from radio shack is a bit "flimsy".
#1568
thanks for the info good tip on the angled plugs, ill try to look for those. im also going to look for a servo extension for the temp probe, almost forgot about that, when i extend the leads and the temp probe is still too short
#1569
Hey those are the same plugs i use
Question.....
on the motor break-in menu, well not on the menu but like on the charger......is there any type of RPM sensor for the ice, using the temp probe slot...
coz i wna know the rpms of my motor but i dont wna go buy another like charger or a dyno....i have put 2 much into this hobby already
Question.....
#1570
b. welcome to this hobby ;-)
#1571
if u find the push button on the dial doesnt work just pull it up about a millimetre its pressed on to a trim pot or rotary switch so once and a awile it move to far down u dont get enough trouble to activate the button.
trust me i had my ice apart as i wanna re paint and anodize it (green fav color)
#1573
A while back, I posted the mod to the back light kit by adding a 12V Regulator that you can buy from Radio Shack for about $3. This will keep the input voltage at the 12V even if you use a higher input voltage such as the 13.8V. You may have to look back kind of far (posted up about a year ago) or search my posts.
#1574
Trader Rating: 23 (96%+)
#1575
to the 3200 carbon lipo owners...
any of yall charge at 6.4?
i was reading on another thread that some dood charges at that rate.
im currently doing it at 3.2 but i am curious on th 6.4 charge rate.
