Lipo battery problem?
I went to charge a 11.1v 2300mah lipo i use for my engine heater and the chager put a warning up saying the the balencer was not connected (it was) and battery voltage is too low, I know you cant run lipo's voltage too low, looks like I have. The question is have I killed this battery or is ther a fix?
May be able to be restored depending on how low you have taken it
Do the following .......... Change charger mode to nimh Connect pack with main leads only (no balance plug) Set charge rate at 1 amp Charge as a nimh pack and watch the screen When pack voltage gets to 6.5v or so stop charger Change to lipo mode Plug in balance lead Charge as normal Cheers |
Originally Posted by crusey_aus
(Post 9907260)
Do the following .......... Change charger mode to nimh Connect pack with main leads only (no balance plug) Set charge rate at 1 amp Charge as a nimh pack and watch the screen When pack voltage gets to 6.5v or so stop charger Change to lipo mode Plug in balance lead Charge as normal Cheers Next time I will check the voltage more often, I didnt realise my engine heater would discharge this battery so quickly, only got about two 15min heating out of this pack. |
| All times are GMT -7. It is currently 04:05 AM. |
