-   -   2.4 and digital servos? (https://www.rctech.net/forum/radio-electronics/564594-2-4-digital-servos.html)
FST4RD 11-01-2011 05:41 PM
If you put a normal non-digital servo with a 2.4 transmitter/receiver setup that requires digital servos what can I expect?
Would not centering properly, curve and steering speed not working properly be issues of this?
These are the issues that I am facing at the moment.
Steve. 11-01-2011 07:37 PM
What kind of radio is it? It helps to know... Futaba radios have either different XMIT modes like PPM/HRS - PPM for analog, HRS for digital servos amd faster frame rate. The 4PKS has "High Speed" and "normal" settings for digital or analog. I'm sure Spektrum and Airtronics have settings like these as well.
AreCee 11-01-2011 08:16 PM
Is it an RTR 2.4 radio? Those are supplied with analog servos out of the box.
You really need to give out some information of what you have if you expect to get a reasonable answer.
FST4RD 11-01-2011 09:22 PM
Sorry guys, I'm running the KO PROPO EX-5UR the sets that come with 2 receivers. So not RTR.
I have tried 4 different analogue servos with no luck on both cars.
I was running a 27mhz AM setup on my F1 car and it worked perfectly. The only reason I got this radio setup was a built a Pro10 car with a brushless setup and it said not to use 27mhz AM setup with the brushless system.
But I have had nothing but issues.
My mate runs the same radio system, so I will try his transmiter on my cars, but that's not going to be for a while.
racer1812 11-01-2011 09:57 PM
I think you're going to have to get a digital servo, you're not the first KO user to ask this question/have issues with analog...KO is also the only brand I've seen that requires a digital servo.
klaymon 11-01-2011 10:02 PM
While the EX-5 says it requires a digital, I have installed that radio on my son's Stampede with the factory servo in it from the old 27MHz system and have had no issues so far. YMMV, but it's been done.
FST4RD 11-01-2011 10:06 PM
Thanks guys...
Might have to bite the bullet and buy a couple servos for my cars.
