Brushed Motor Help
Old 11-01-2011 | 05:22 PM
CamZH's Avatar
Default Brushed Motor Help
Yeah, I know, who uses these anymore ?
Anyhow, I had some of these BNIP from a few years ago and figured i should put one into use in my Wife's RC10T3...
It's an Orion Core Stock:
Anyhow.
After a lap or 2 around the track its started to die, loosing power and then just wouldn't move.
Had a quick visual inspection and couldnt see anything strange, no burnt brushes or anything.
However, I did notice that after pulling the brush away from the comm and letting it reseat it would start to move again.
Is there some kind of run in procedure for a motor like this ?
Never had problems like this before with a new motor...
Anyone got any ideas ?
CamZH is offline
Old 11-01-2011 | 08:12 PM
I take 2 AA batteries and run them in series directly to the motor until they are dead. This runs the motor slowly breaking the brushes in. I just use tape to hold the batteries together. When they are dead I clean out the motor with motor cleaner and then re-oil the bearings.
fredswain is offline
Old 11-01-2011 | 08:27 PM
CamZH's Avatar
thanks for the pointers Fred,
Do you think this is likly to be a run in issue, or somehting more serious ?
CamZH is offline
Old 11-01-2011 | 09:25 PM
TOM MAR's Avatar
You might check your LHS. Get some stronger brush springs, you got a brush hung up. A commen problem with brushed motors running in offroad.
TOM MAR is offline
Old 11-02-2011 | 04:13 AM
ta04evah's Avatar
+1
If the motor has been sitting around for a long time the springs may have weakend and you may need to get new brush springs or take them off and bend them a little bit so they press down on the brush harder.
As above a common problem with older brushed motors.
Cheers
Rob.
ta04evah is offline
Old 11-02-2011 | 08:58 PM
CamZH's Avatar
thanks for the tips guys,
I'll try some new brish springs.
CamZH is offline
