Mamba Max Pro help
I installed a MMP with a Tekin Redline 13.5 in my wraith. All went well and I was able to program my settings using the remote (spektrum DX3) and the procedure in the manual. But the settings wont save, or take affect. Am I missing something here? Do you have to save them somehow? At first I forgot to hook up the sensor wire from the motor to the esc and thought that might have been the problem. Then I hooked the wire up and still I can't get the settings to save.
Any insight would be a big help
You need to set the arming time to at least 2,5 seconds for Spektrum TX. You should really use the Castle Link to set up these ESCs, there should have been a coupon for a free Link in the box if you bought one within the last 18 months.
The ESC defaults back to Sensorless if it does not sense a sensored motor at power up. Try programming it again with the sensor wire attached first. These ESCs are a pain to set up through the TX, the Link or Field Card is a MUST HAVE .
