ko chargers
has anyone had experience with the ko pc101l charger good points bad points ease of use and set up does it have memory for different settings like the lrp comp 3 does is it a worthy upgrade to an lrp or not are there similar units out there that might be cheaper or better for the same price or will i be ahead to keep the lrp thanks
Sup Gomer! I've been using the KO PC-101L for over a month now and feel it works very well. It doesn't have setting memory like you mentioned but it's extremely easy to adjust. It has a built in fan so I can charge batteries almost non-stop. I use to own a Hyperion 0606i and always had to run an inconvenient fan over it. However, the Hyperion also work good too. I have no experience of other chargers so I can't say much else. Oh, it's also convenient not having to carry a power supply like others do. I guess I'm not that hard-core
Let me know if you have any other questions.
