TP610 AC/DC problem
that charger only puts out about 7 - 7.5 amps on wall power. Reduce your wall power settings to 7amp or below and it should be fine.
on DC power you can run a full 10amps
edit: on second thought, what batteries are you charging? the 7-7.5amp comment only applies to 7.4v lipos. If your charging 3S or bigger you will need to use an even lower amp setting.
On the LED screen CC output is zero. I get the error about 15 sec into charging.
