LRP ESCs - Version 2 stuff >
Old 10-06-2011 | 11:45 AM
klaymon's Avatar
Default LRP ESCs - Version 2 stuff
I've had a couple of people tell me that they did not like the version 2 LRP ESCs. I was directed to the 07 Sphere Comp for example. Is there something about these newer versions that makes them not as desirable? Obviously, the older stuff is hard to come buy and all the dealers have the version 2 stuff. This will be off-road in 2wd mod buggy (10.5) and 2wd mod SCT (9.5) if it matters.
Thanks.
klaymon is offline
Old 10-06-2011 | 01:08 PM
MarkA's Avatar
I have no idea why anyone would direct you to such an old ESC over LRP's newer stuff. I have 2 of the v.2 LRP's and love them both. I even had the fan come off the TC v.2 (dirt got in it and the blades came off; cheap fix) that I use with a 4.5 in my 4wd SC truck, ran the main anyway, and it wasn't even close to hot.
MarkA is offline
Old 10-06-2011 | 01:46 PM
klaymon's Avatar
So how about this one for the above-mentioned applications: http://www.amainhobbies.com/product_...-Brushless-ESC
klaymon is offline
Old 10-06-2011 | 01:58 PM
MarkA's Avatar
That will work awesome in those cars with those motors.
MarkA is offline
Old 10-06-2011 | 02:04 PM
klaymon's Avatar
Thanks.
klaymon is offline
Old 10-09-2011 | 06:53 PM
anotherrcguy's Avatar
I have 2 of the v2 comps and I love them. Used to run tekin now run lrp
anotherrcguy is offline
Old 10-10-2011 | 08:45 AM
cnelson3's Avatar
they are a little softer and easier to drive. also the brakes are a little different. I happen to really like the v2 because you can separate the boost and throttle profiles. If you spend a little more time tuning those two settings, you'll be happy with the v2's. IDK about the brakes tho, they aren't like the older models. i'm really not sure why. they are softer when the car is going slow. I think they are the same when you are at speed. not much i can say about that. i dial my brakes down low anyways so it took me 5 mins to get used to it.
cnelson3 is offline
