SC450 Brushless won't reverse throttle >
Old 09-27-2011 | 06:47 AM
RickSlick's Avatar
Default SC450 Brushless won't reverse throttle
Got a new B4.1 and I realize there is a 1 second delay for safety before you can engage reverse. However, even after waiting much more than 1 second and sometimes no matter how long I wait, I can't go into reverse. I have adjusted the trim to the far side of forward/reverse and this still does not help.
Anyone know of any ongoing problems with this ESC regarding reverse problems?
Thanks, Rick
RickSlick is offline
Old 09-27-2011 | 07:07 AM
Centre your throttle trim
Set your throttle / brake travel (EPA's) at 100%
Calibrate the ESC to your transmitter
ESC probably has a profile that does not have reverse, most do
Read the manual that came with the car
Cheers
crusey_aus is offline
Old 09-29-2011 | 11:13 AM
Jsutherland8's Avatar
You may have to reset the trim down or up to get a "0" nutral position.
Jsutherland8 is offline
Old 09-29-2011 | 12:44 PM
RickSlick's Avatar
Hobby shop helped, got it fixed...........thanks
