? on parallel charging
So we now have our new charging station setup consisting of an i306B, 47A PSU and a parallel board from EP Buddy. Awesome setup, charging a single 5000 Mah 5S in 9 min....sweet.
Now the info I've seen/heard on charging multiple packs is make sure cell counts are the same.....got it.
But as far as Mah's goes, some are charging with different capacities, some say make sure Mah's are the same. So which way is correct?
In parallel, same cell counts, can be diff capacities....
http://www.rchelicopterfun.com/paral...-charging.html
See 6th paragraph - they can be diff capacities (within reason) - you wouldn't parallel charge 2200, 4000, 6000 and a 450mah 2S lipos together.
Most of what you see on the net as examples are the same capacities, but that's just because that's what they need or have to charge, not that it's required part of parallel charging.
