Hyperion 0606i question
Just picked one of these up and I have a question about what is displayed as it charges. I charged a 4200mah 2S last night and when the cycle stopped the mah was only 2754. Does that mean there was 1446mah in the battery when I started? (battery is almost new)
If so how can I check the total mah of a charged battery?
Looking at it another way, you replaced 66% of the lipos capacity. Lipo doesn't like being over discharged which is defined as more than 80% of capacity.
So as long as you don't see more than 3360mah going back in on recharging, your lipo should be happy. This should work out to be close to 3.7v/cell 'resting' voltage. Voltage will be a little lower immediately after running, lipo does have some voltage recovery.
