Servo maintenance??
Old 09-12-2011 | 07:44 PM
Default Servo maintenance??
got a Savox 1256 for about 6 mos now and it just started making a new louder than normal noise. It sounds like the gears inside are touching something each rev (squeak-squeak-squeak). Is there something I can do to check it out? maybe open it and maybe clean inside or replace some parts?? thanks.
update: ok i just saw they sell the gear sets but manual is nowhere to be found
mk74 is offline
Old 09-13-2011 | 03:45 PM
HarryLeach's Avatar
Do you run in dusty and/or wet conditions?
Sounds like the bearings need to be cleaned and lubed. Gears don't normally squeak. The gears might break and you get a crunchy sound, but not squeaking.
Open up the gear case, paying close attention to where everything goes, clean everything up with some plastic safe electronics cleaning spray, and re-assemble with some white lithium grease on the gears and bearings [a little goes a long way].
As long as the bearings can be cleaned and freed up, it should quiet down for you.
HarryLeach is offline
Old 09-19-2011 | 12:26 PM
Mxer59's Avatar
They servos are just naturally loud I've replaced my gears once due to hitting someone while turning and caused it to strip two teeth. My savox always has a squeaky hum to it
Mxer59 is offline
