HOT motor!
Old 07-22-2011 | 07:02 PM
MTclassPro's Avatar
Exclamation HOT motor!
ok not sure if this is in the right section but i was going to ask for some help from the rc community.
so ive been out of the hobby for a while and just took my bl 18t out and noticed the motor gets HOT. hold your finger on there for a few seconds and it starts to get hot. i have 14/60 gearing with a tekin mini rage 8000kv motor. so what i was wondering is why the hell is it getting so hot?
maybe the gearing is geared to high orrr??
any input im sure would be helpful!
Thanks.
-dan
MTclassPro is offline
Old 07-22-2011 | 09:40 PM
Its getting hot because you are loading up the motor too much
Lower your pinion and temps will come down
Cheers
crusey_aus is offline
Old 07-23-2011 | 09:07 AM
MTclassPro's Avatar
Exclamation
Cheers
maybe 11t?
or is that too low?
Old 07-23-2011 | 04:32 PM
Check that your gear mesh is not too tight.
mooby64 is offline
Old 07-23-2011 | 05:51 PM
I'm new to BL too so take this as a noob to noob. If you are holding your finger there for a "few seconds" then I'm not sure if you are too far off on gearing. From what I understand, temps in the 130*F range is "normal." I would suggest getting a temp gun so you can check to be sure.
Hope this helps
Mark
mark in wi is offline
Old 07-23-2011 | 08:44 PM
MTclassPro's Avatar
gear mesh isnt too tight
Old 07-25-2011 | 08:35 PM
Nitro1000's Avatar
My recommend that you take it in to a hobby store and talk to a person there
Hope you get I fixed
Nitro1000 is offline
