-   -   Something Doesnt Seem Right (https://www.rctech.net/forum/radio-electronics/534065-something-doesnt-seem-right.html)
faze 07-19-2011 02:56 PM
Im running a Novak Ballistic 6.5t motor, it has the larger sinstered tuning rotor also. Anyways, It seems really difficult to spin by hand (with the pinion gear on), the bearings in the motor are brand new, and the motor is clean. Then when I turn the truck on, and try and run the motor for a few mins (motor not atattched to the car), it seems like it gets hot really quick. The back of the motor got about 130 in just a minute or two, and the rest of the motor stayed around 110-120.
The big thing I notice is that when I apply throttle and let off, the motor does not free spin, it immediatly stops spinning. Seems like the rotor should spin with no throttle applyed for a few seconds after letting off the throttle.
What could be wrong?
td-civ 07-19-2011 07:51 PM
it should have a little play in the shaft if it dont something is not seated right
faze 07-19-2011 07:59 PM
Thanks! Yeah I pulled one of the washers out and it spins alot more freely now, I probably should pull on more out if theres supposed to be a little bit of play in the shaft.... Its loose, but theres no play.
td-civ 07-19-2011 08:05 PM
sunds like your good now you just want a little bit of play but not much at all
faze 07-19-2011 08:17 PM
Sweet! Thanks for the help!
NovakTwo 07-20-2011 08:08 AM
Check out this "Free Revving" warning.
If you have additional questions, please contact [email protected].
