Tekin Capacitor help! >
Old 07-19-2011 | 05:25 AM
brothainchrist0's Avatar
Default Tekin Capacitor help!
hey guys, i'm going to be running 3 different tekin set ups and this is the first time i have ever had to worry about capacitors. Anyways, here is my set up:
rx8 - 4.5t sc4x sensored - 2s lipo
rx8 - 1400kv sensored - 6s lipo
rs pro - 8.5 t sensored - 2s lipo
Do i need a capacitor for any of these set ups and if so, which ones do i need? What do the capacitors do?
Thanks!
kyle
brothainchrist0 is offline
Old 07-19-2011 | 12:23 PM
onefast8's Avatar
I use them on everything but the sc4x will prob be the most taxed setup you have. At 5 bucks its not a bank breaker.
The caps help the bec in the esc with the high demands of the fast/strong servos made today.
http://www.amainhobbies.com/product_...tage-Protector
Hope this helps.
Thank YOU.
onefast8 is offline
Old 07-19-2011 | 07:48 PM
td-civ's Avatar
Thanks!
kyle
this is what i run on my rx8 and rs pro
http://cgi.ebay.ca/ORCA-ESC-Capacito...item1e64cc5c72
or you can just run 2caps but it will work with just 1 i just run 4 to be on the safe side
td-civ is offline
Old 07-19-2011 | 08:20 PM
STLNLST's Avatar
It would be wise to run the caps that come with the speedos. They work the best. I run 2 on mine when running them with the lower wind motors.
STLNLST is offline
Old 07-26-2011 | 09:06 AM
Do the esc's come with capacitors when u order them or do u have to order them separately?
Old 07-26-2011 | 09:14 AM
20 SMOKE's Avatar
it comes with one
20 SMOKE is offline
Old 07-31-2011 | 10:56 PM
DesmoDave's Avatar
The stock Tekin ones keep breaking. The leads are snapping off at the base of the body. I need something with stronger leads, but I'm having a hard time finding a 330 uF Cap local. I have a 440 uF. That would work, I would think without causing a problem. It sounds like they will just power up (sorry, I'm pretty rusty on my electronics theory with the voltage supplied, the uF is the overall capacity... so it might even be a little better?
At any rate, I came off the track last night after racing and found that one of the leads on the cap was broken, again. I have the leads as short as possible and the cap is right on top of the ESC, and it's well covered by the body of my SCT.
Any thoughts or suggestions, besides becoming a better driver (working on that too).
DesmoDave is offline
Old 08-01-2011 | 03:44 AM
L@gger's Avatar
I snap my capacitor to tekins body by silicone and leads never breaks.
L@gger is offline
