Roar ruling on 8.5v
I know what I'm doing, IDK if the person next to me does though...
'overcharging' your batt is not dangerous if you know what your doing and have 'good' batteries(new, not puffed, low IR, etc). Its not until you get joe schmo that wants to get every last race out of his $150 battery that is 4 years old, puffed, and about to blow on its own, that you start to have issues...
Pay attention to your batts and you won't have any issues...
I charge to 4.2v per cell... but thats what ive always been told and thats what my "smart" charger is setup to do. i always balance charge as well.
sorry to sound like a noob, but what is the deal with this? why are they rated at 3.7v but charge up to ~4.2v per cell? EVERYONE i know or have seen at the track does this as well.
i really don't see the point of overcharging your batts by such a small amount when they'll drop to nominal fairly quickly anyway. seems like it's just a good way to blow your batteries with no real benefits.
They're not really 'rated' at 3.7cv/cell, just referred to like that. This is called the 'nominal' voltage. Not much diff than a sub c or AA NiMh cell where they're referred to as 1.2v/cell when they charge to higher than that.
Supposedly, the 3.7v/cell is what a lipo cell drops to under load.....
This thread comes from Roar changing the max allowable voltage at roar events to 8.5v.
At events, racers are going to push every rule to their limits. So if the max allowable voltage is 8.5v, they are going to charge their packs to 8.5v.
How safe is this? How much damage are you doing to your cells?
8.4v vs 8.5v, hardly a noticeable difference
Early non balance lipo chargers used to charge to 4.3v / cell
Once they started to realize it reduced pack lifespan people started to lower it
You seriously think there would be any performance increase at all ?
Have you seen a high current discharge graph ?
Look at how long the voltage stays above 4v
Cheers
Cheers
What ROAR is doing is plain silly and dangerous. Here's why:
1. Most chargers are set to cut off between 8.4 to 8.44 volts. I've seen some mis-calibrated chargers take them to 8.46.
2. By allowing the 8.5 limit at racing events, they are essentially saying it's OK to take your pack to 8.5, which can only be done if you by-pass the charge limit. In my personal case I have a Much More silent charger. It cuts off at 8.40-8.41. The only way I could get it to reach 8.5 is to re-peak the pack in HiMh mode. If you do this you will have to sit and monitor your charger until it hits that voltage. What if someone forgets to do that??? Your battery will continue to charge.
Just my opionion as a race organizer and director.
I can set my Icharger anywhere between 4.1-4.3v a cell... just because your charger can't doesn't mean that others cant...
EDIT: I've found that the difference between 4.1v and 4.3v a cell is about 500mah on a 5000mah battery...
BTW my charger will let me charge to 8.6v......IF I want too
Apparently I missed this. Where did ROAR declare the upper limit to now be 8.5V?
I've had cheaper chargers that I found to be quite safe with my batteries, but showed a peaked battery above 8.4V during tech. This could be an effort to ease the burden of cost in upgrading to an adjustable peak LiPo charger [which I have upgraded to for the ability to adjust my peak to meet tech with less hassle].
