Jato electronics issue (newbie)
I got a Jato in a trade, it was dirty and needed a new chassis top plate. I replaced the chassis top plate and now when I plug in the battery pack, regardless of the power switch on/off, the steering servo powers up. the throttle servo does not and the on/off switch no longer works. everything is plugged in based on the manual.
It all worked before I took it apart, but I cant figure out what I did wrong or broke. Any ideas? |
Did you accidentally plug the servo into the battery slot on the receiver?
Dan |
That's what I thought I did, but I checked and it was in the correct slot.
I also forgot to add, the throttle servo is brand new. is there any new procedure I need to do inorder for it to work? |
Originally Posted by Dan-RC
(Post 9374015)
Dan |
| All times are GMT -7. It is currently 10:36 PM. |
