gt3b problems
Old 06-20-2011 | 08:57 PM
Default gt3b problems
hey all i jus bought a gt3b i got it to bind properly the only prob im having is the throttle is reversed (pull on the trigger i get reverse) any ways to adjust that? i have a rx8 esc. another side note im not getting ne power when the esc is pluged in ch. 3 thanks in advanced for the help
jamminman909 is offline
Old 06-20-2011 | 09:01 PM
Jtipsy's Avatar
have to turn the reverse motor on with the programmer or manually program it
Jtipsy is offline
Old 06-20-2011 | 09:04 PM
Motor direction can be changed in a few different ways
Direction can be changed in the ESC
If you are using a sensorless motor then you can simply swap any two motor wires
Cheers
crusey_aus is offline
Old 06-20-2011 | 09:11 PM
its a sensored motor (havok 4.5) what about the ch.3 not giving me anything but the fan to turn on. ive been out of the rc game for a while n jus bought the truck a week ago i dont know much. me= scrub
Old 06-23-2011 | 12:33 AM
beemerfan's Avatar
Have you tried calibrating the speed control with the radio? Novaks don't seem to care if your throttle channel (2) is set to normal or reverse, they should calibrate either way. However, if after calibration it still runs in reverse, then set channel 2 on the radio to REV and calibrate it again. Not sure what you are asking about channel 3. Novak has manuals on their web site if you need help calibrating the speed control.
beemerfan is offline
