servo motion question >
Old 06-14-2011 | 03:58 PM
Default servo motion question
is there any way to get a servo to rotate to its end point?
I just bought a traxxas 2075 and when I rotate it manually it can rotate 180 degrees, when I use my remote (stock traxxas link 2.4) I can only get it to rotate a max of 90 degrees.
Any way to get it to rotate the full 180? Change gears out perhaps? Thanks
ragefear is offline
Old 06-14-2011 | 05:12 PM
Not sure why you would want to do that?
Standard solution for more travel is a longer servo horn/arm. Will reduce the force it can generate correspondingly of course.
Not so much travel left after +/-45 degrees, well at least assuming a typical set up. Perhaps you are trying to use it differently?
Dave H is offline
