Cogging issue with set up
Well I have changed out the motor and still same cogging issue.. I can help the cogging by turning down my expo and slowly hitting the throttle.. if I go from nuetral to full throttle it just puts/hesitates...
MMP (Mamba max pro) 1.26 version, dual mode on spektrum reciever Micro Hitec 965 servo Tekin redline 8.5 Novak 5.5 (2nd motor same issue) 3 seperate sensor wires 6000mah saddle pack 25c (if it matters) with OR without novak glitch buster same issue. any one????? THANK YOU!! |
Originally Posted by jnelson214
(Post 9161236)
Originally Posted by burnineyes
(Post 9161304)
In my experience, a full throttle cogging like that is almost always caused by a weak battery or poor connections somewhere between the battery and motor. The fact that it starts better when you give it throttle slowly tells me the problem happens when current draw is high. 6000mah 25C should be enough to power either of those motors assuming it is in decent condition, so I would look to connections first. What kind of battery and motor connectors? Have you replaced any of them? Sorry if this has been covered, it sounds like you have posted something about this before but I am not familiar with it. Is this a problem that started all-of-a-sudden or did it start with all new components?
thanks |
Just a suggestion, but you might try rolling back the esc firmware to an earlier version ans see if that helps.
I read about a similar prob that was solved by rolling back to 1.21.... |
In your settings, did you try high power starts ?
(Post 9161304)
| All times are GMT -7. It is currently 04:04 AM. |
