turnigy battery problem
#16
My manual states:
"In this mode, the charging process will be different from ordinary charging mode. The internal processor of the charger will monitor the voltages of each cell of the battery pack and controls the charging current that is feeding to each cell to normalize the voltage."
so I think this is different than a balancer only. Plus, from my experience, when I charged a 2S with cells out by about 0.3 to 0.4V, they started to normalize well before the higher one hit 4.2V.
The example of cells coming into balance when charging does not necessarily mean the charger is balancing. It could just be the cells returning to a previously balanced charged state. Think about it, if one has a balanced and charged lipo, assume the cells are different capacity, when discharged they will end up at different charge states-voltages, out of balance. But since the same amount of current was drained from them, they tend to rebalance all on their own while charging. Note balancing is important as cells change over time (which they will).
Note for this reason it is generally a mistake to balance a discharged lipo. Best to balance at the end while charging. All balancing a discharged out of balance lipo does is cause more balancing while charging (and risks over discharge), not good.
In practice some different brands of chargers apply balancing differently. The PowerLab 8 charger for example can even be adjusted/configured for when balancing occurs as I understand it. (And has king of the hill balancing power, 1 amp I believe)
Hope this helps some, can be tricky to explain well.
