EVX 14.4 3014 problem >
Old 05-07-2011 | 08:58 AM
Default EVX 14.4 3014 problem
I just bought a used E-Maxx. When I start it moving, it just takes off and I have no control over it. It goes until it crashes and the batteries fall out. Does this mean the speed control is toast? I read somewhere about a guy who had Traxxas refurbish his speed control. Is that a possiblility? Any help would be greatly appreciated.
dlee117 is offline
Old 05-07-2011 | 09:12 AM
Sounds like esc may have lost its calibration. Did you change radio?
I would try re-calibrating the radio to the esc. Look in the manual and go through the calibration procedure.
Duster_360 is offline
Old 05-08-2011 | 12:38 PM
Default ESC Traxxas
Duster,
Thanks for responding. No, the ESC is the one that came with it. I don't have a manual for it, so I will look online to see if I can download one and try the calibration. I'll keep you posted.
Dlee
dlee117 is offline
Old 05-08-2011 | 01:04 PM
Default My ESC
Duster,
I just posted to your account, but not knowing which is best, I am reposting here.
Dlee
Duster,
I'm the fellow with the E-Maxx and the ESC problem. I am looking up the manual. How do I tell what model I have. There are no markings that I can find. The ESC is a Traxxas EVX 14.4 mdl 3014. The receiver is Traxxas 2215, 27 mhz. Motors are Titan Monster 550,s. Thanks again for your help.
Dlee
dlee117 is offline
Old 05-08-2011 | 02:12 PM
Its covered in the manual, but lets be sure its not something else first. You are turning the radio on 1st? You always turn the radio on 1st - that way when you turn the rcvr in the E-Maxx on, it 'sees' the correct radio signal and only that signal. If you turn the RC on 1st, you can have a run away similar to what you describe.
If you're not sure, try it this way, but set your E-Maxx on something so the wheels are off the ground where it can't run off. Turn teh TQ radio on 1st, then the E-Maxx rcvr.
This is the manual that came with the 3906 model E-Maxx with the 3014 EVX -
http://traxxas.com/pdfs/3906_manual-2002.pdf
Start reading the manual linked above on page 25 - speed control programming starts middle of the next page.
Old 05-08-2011 | 02:23 PM
Suspended
Switch it out with something that is worth it. Traxxs has really never made anything worth a damn.
You might have a bad radio, or ESC.
Make sure your trim is set correctly, and go through the setup procedure.
If all else fails, buy something that is actually worth a damn. Hobbywing, Novak, Tekin, LRP are all good products.
Metalsoft is offline
Old 05-08-2011 | 04:30 PM
Default Confused
Metal,
Thank you for your input, but I am somewhat confused. I am new to the RC arena. My confusion is that my Traxxas 3014 ESC is manufactured by Novak which you say is a good unit.
Dlee
dlee117 is offline
Old 05-14-2011 | 12:05 PM
If you contract Traxxas, they will tell you to go to their site, register your truck, and go through a process to open a work order. Then it's 50 bucks, plus shipping to Traxxas to refurbish it.
I would try going through the setup on the ESC since it only takes a few moments and it's free.
Also, if you think your Transmitter or reciever are to blame, there are quite a few budget friendly upgrades for an early Emaxx.
Tbird232ci is offline
