Futaba 4PK and R614FF problem >
Old 05-01-2011 | 01:49 AM
Losimoe's Avatar
Default Futaba 4PK and R614FF problem
hey guys,
im using my old 4PK with the R614FF receiver for about 3 months now without a problem.
but racing today changed the whole story. in a 7 min heats, my receiver went to fail safe mode over 10 times for about 1 second each time then get back to full control. it was running fine before.
im running a lipo rx with hitec high voltage 7940 and 7950. changing to 6v hump pack didnt help either.
its definitely is the R614FF receiver that was toying around. i change to the old R604FS receiver and run a 6v nimh hump pack and the problem went away.
any thoughts on what could have been the cause??
Losimoe is offline
Old 05-01-2011 | 07:41 AM
cherokee95's Avatar
Considering the 614FF is the high voltage RX, that doesn't make any sense at all. My only suggestions are to make sure your antenna is upright. I did have a couple fail safe interruptions, indoors surrounded by other 2.4 radios and routers, before I ran my antenna outside the body. Shouldn't need it, but you could try a glitch buster.....I would call Futaba on Monday and explain the issue to them. They have great customer service in my experience.
cherokee95 is offline
