Lipo discharge
Im going to be buying a few 4c lipos comming up and i was told on an 1/8 scale 4x4 u cant use less than a 35c. can anyone tell me if this is correct. I mean im not planning on going lower i just wanted to see my opyions
Battery choice should be determined by the amp draw of your motor
Decide on a motor
Find out the burst amp draw
Get batteries that are able to supply a constant rate equal to the burst rate of your motor
Example
Motor with 100 Amp Burst
Option 1 - 5000mah 20c pack = 100 amps
Option 2 - 5000mah 30c pack = 150 amps
Option 2 is a better choice as option 1 is borderline
Generally speaking packs that have a higher discharge 'c' rating will hold a higher voltage under load
More volts = more speed
Cheers
Decide on a motor
Example
Cheers
