Please help the ignorant. >
Old 03-25-2011 | 02:24 PM
Default Please help the ignorant.
Can someone please walk me through how to check lipo voltage using a voltmeter? My batteries are all 2S with bullet plugs built into the case. Can the voltmeter be used to check cell balance as well? I am sure this is insanely easy, but never having done it before I want to avoid doing anything stupid. I have never used a voltmeter before, so please start with how it should be set and go from there. Thank you.
JMYBFFT is offline
Old 03-25-2011 | 02:47 PM
Set scale on voltmeter to 20v dc range
Measure between red and black main battery leads willl give you overall pack voltage
You may need a different probe for balance plugs, they are pretty small
Measure between first lead and second lead in balance plug for cell 1 voltage
Measure between second lead and third lead in balance plug for cell 2 voltage
Voltages should be
Pack
Between 6 and 8.4v
Cells
Between 3 and 4.2v
Cheers
crusey_aus is offline
Old 03-25-2011 | 03:08 PM
When checking voltage off the balance plug, be careful not to let the pos and neg probes touch!! Thats a direct short and you don't want to short a lipo.
I have done this plenty and it just takes angling the probes away from each other as you're checking the various ones.
Duster_360 is offline
Old 03-25-2011 | 03:33 PM
Thank you. I will let you know if I get it figured out without starting any fires.
JMYBFFT is offline
