1/8 scale battery size Question
I have an 1/8 scale truggy and my ESC can handle up to a 4cell-14.8v lipo. What is the difference in using 5000mah and a 3000mah. is there a power difference??
Originally Posted by Mindcrimes
(Post 8840575)
Battery choice should be determined by the motor
Your motor will have a continuous current rating Example 100 Amp motor Pack 1 - 5000mah 20c pack = capable of delivering 100 amps Pack 2 - 5000mah 40c pack = capable of delivering 200 amps Pack 2 is a better choice as 1 is close to its limit Generally speaking higher mah = longer runtime as long as the packs can keep up with the motor Cheers |
(Post 8840575)
If both 5000 and 3000mah have the same C rating, there shouldn't be a power difference. The 5000 will provide longer run time. Its not really that simple though as the motor is what drives the amp demand in a setup. |
yes... your 3000mah will come off the size of a football after being run...
| All times are GMT -7. It is currently 09:01 PM. |
