Charger help
Old 03-20-2011 | 02:59 AM
bl4's Avatar
bl4
Default Charger help
Can anyone here to recommend a good charger not to bulky.
Need a charger for my touring thks.
bl4 is offline
Old 03-20-2011 | 06:33 AM
the power thunder no power supply needed. it will charge everything only
129$
Graphite07 is offline
Old 03-20-2011 | 06:43 AM
bl4's Avatar
bl4
129$
What model isit TP610C?
bl4 is offline
Old 03-20-2011 | 07:11 AM
Thunder Power TP610C-ACDC1-6ClLiPoACDCChrgrBal THP610CACDC
http://www.amainhobbies.com/product_...rce=google_ext
this one is awesome. i have two of them but my chargers use the power supply.
Old 03-20-2011 | 07:35 AM
bl4's Avatar
bl4
I though of getting the THP610 as I have a power supply now. Thks for the info.
bl4 is offline
Old 03-20-2011 | 02:42 PM
If you have a power supply already, this is a smaller charger and will balance charge 2S lipos up to 5amps.
http://www.amainhobbies.com/product_...rger-6S-5A-50W
Really you need to say what batts you plan on charging....
Duster_360 is offline
Old 03-21-2011 | 05:32 AM
bl4's Avatar
bl4
Most likely on 2S Lipo 50c and above
bl4 is offline
Old 03-21-2011 | 05:37 AM
bl4's Avatar
bl4
Isit better to choose a higher A for charge current?
bl4 is offline
Old 03-21-2011 | 05:41 AM
ntrain42's Avatar
Stay away from thunder power, those chargers are garbage, poor QC. Look for ANY iCharger. 106b, 206b, 306b depending on your needs. Best built constant current chargers on the market.
ntrain42 is offline
Old 03-21-2011 | 04:31 PM
There is something to be said for allowing yourself some head room charge rate wise, but only if you plan on using it. If your lipos are capable of higher tnan 1C charging or you're going to be buying higher cells count lips that are, its def something to consider.
I use a 30amp charge rate iCharger 3010b, but I frequently charge lipos in parallel and use charge rates up to 30amps. If I was only running 2S and was satisfied with 1C charge rates, there'd be little reason to spend the money to buy a 30amp charger and capable power supply.
Old 03-21-2011 | 05:43 PM
bl4's Avatar
bl4
Thank for your info.
I am comparing protek and icharger, will choose between this 2 brands.
bl4 is offline
Old 03-21-2011 | 08:23 PM
okay had mine for a (YEAR NOW) and going strong. and all the racers have them at the track i race at and i have not heard anything bad from anyone.
maybe just becuase you got a a bad one. but then again you always have that (ONE PERSON) who says YEA thats junk. my local hobby shop cant keem them in stock so i guess they are good.
Old 03-21-2011 | 08:53 PM
I second that, mine stopped working after a couple months.... warranty <3
johndenver is offline
Old 03-22-2011 | 04:56 AM
I have two of them one being over a year old and the other about
6 months old. Still going strong and one racer at the track had hIs for a long
Time
Old 03-23-2011 | 01:06 AM
bl4's Avatar
bl4
Protek Prodigy 65 and Junsi icharger 106B+ which one is the best choice?
bl4 is offline
