LIPO BATTERY HELP!!
Hello,I have a dynamite passport ultra lipo charger here is my question. I have a protek 14.8v 4s 2200 battery I use for my bump box seems everytime I go to charge it it goes into unbalance voltage for quite a while does this mean the battery is bad it has done this since I bought it I balance charge it at 2.2 any help would be appreciated Thank,s
Originally Posted by Bugman
(Post 8819841)
Originally Posted by FantomLeopard
(Post 8820225)
I'm not sure I understand the question. The battery starts balancing for a while? Or it is unbalanced for a while and then before it completes the charge it is balanced?
Oh, yeah. That should be normal then. Batteries balance when they are charging but when they discharge they tend to unbalance a bit. I don't use any 4s Li-po's but I would imagine they would discharge a bit more unbalanced than my 2's ;) As long as you keep on balance charging them you should be fine. About how far off are the cells from each other voltage-wise?
I think not that far off it usually reads 4.17,4.17,4.17,4.16 if my memory is correct.but i will check to make sure just have to charge it again and take a look.Thank,s
Sorry :) I meant how far off are they from each other after they have been discharged ;) As long as they are ending up nicely balanced like that at the end of a charge though they should be fine! Just make sure not to over-discharge them!
If you are seeing a message while charging that says 'unbalanced volt xx mv" this is normal charger provided max voltage diff between the high and low cell. It doesn't mean anything is wrong, its just info the charger provides.
| All times are GMT -7. It is currently 02:53 AM. |
