reception problem with 1/8th buggy? help!
hey guys i have a lrp s8bx rtr buggy and it was going fine and all good and everything, but the other day when it went 10 or 15 metres away from me it just had a mind of its own and went crazy but then if i ran withing 10 metres or so it would be normal, whats the problem? also it isnt the crystals causei tried that, any help would be appreciated thanks
jack |
not sure what kind of radio you have but here is some things to look for, if it is an am radio look for some metal clanging such as crab & brake linkage, clutch bell to spur gear the metal to metal contact can make a real nice glitch. hope this helps.
Originally Posted by marto1996
(Post 8810126)
jack change the remote control,there is something wrong inside the main board, and i prefer to use 2.4 remote control. |
thanks heaps guys, any other help greatly appreciated
I got the same buggy and had a similar problem but its all good now, things to check are that your reciever and transmitter batteries are fully charged, make sure your aerial is FULLY up, 3/4 is not good enough, make sure you don't drive with a broken buggy aerial. It sounds obvious but it worked for me.
It's already been eluded to, but be sure the aerial on the radio is at full length, as well as the one on the receiver. You should never cut the wire on the receiver because it's tuned for the frequency range. If you cut it, then you will certainly lose range, and it may cause some of the radio components to overheat from having to work too hard. Before you start checking anything, be sure you have fresh batteries for both the receiver AND transmitter.
They should be fresh. As a last resort, you should find someone that has a different pair of crystals to see if that's the problem (or their is local interference on your particular channel). If none of this works, you've eliminated all the easy-to-fix problems and it's probably going to require a new radio. |
Have your wires neat and clean inside the RX box. All of mine are folded and wire tied and neatly placed in the box. You will/could get bad signals if wires are all over the place like a rat nest.
| All times are GMT -7. It is currently 04:12 PM. |
