-   -   Charging at the field (https://www.rctech.net/forum/radio-electronics/488764-charging-field.html)
schnellschnell 03-04-2011 07:14 PM
What do you guys do at fields with no AC?
Generators? Batteries?
It is a bit of a drive for me to get to the track and I don't want to need a dozen LiPos charged every time - I'd rather charge there.
At the same time, I don't always have room in the car for big gennys if the family is coming.
How long will a Pb battery last charging 5000mAh 4s batts? Other ideas?
j
FantomLeopard 03-06-2011 10:23 AM
j
Well, some guys will use their car batteries which do last a bit, just make sure your charger has a cut-off so it doesn't over discharge the car battery (pretty much all chargers with the cables to charge from a car battery will have this option), others will use power supplies, which you can charge and then use to charge your batteries at the track but these can be a bit expensive. What I really suggest doing is just charge your batteries the day before or the day of and then just take them to the track charged. It works for me :)
tmaxx26power 03-06-2011 04:24 PM
I always run 4 chargers all race day long off of my vehicle battery and have never ended up with a dead battery. Maybe it's the power of an Interstate:D
