Orion4500 rocketpack 8.4v >
Old 02-27-2011 | 05:28 AM
Default Orion4500 rocketpack 8.4v
Just bought the Orion clubmanedition advantage to use as a charger to the 4500 rocketpack, now how do i power this charger?
qap15 is offline
Old 02-27-2011 | 05:47 AM
RCaddict0's Avatar
Default Your gonna need a 12v/DC power supply
I just copied/pasted it and looked at the pick. I didnt read anything on it. But Im almost shure. You can get a 110AC/DC adaptor at Radio shack. But make shure it supplies enough amps. You dont need to buy a $100 power supply unless your planning to charge at fast/high rates. I would think a 12v/5A would work. I use a cheap a$$ one from Hobbypartz. But its outta stock right now. Check around. Hobbyking should have some cheap ones. Or you could possably use a car battery charger. It just needs to supply 12v DC power. You charger should have recomended minimum requirements for "input power"
RCaddict0 is offline
Old 02-27-2011 | 05:57 AM
I have several 12v adapters at home but none seems to work, could be the current is not enough, the highest 1200mA.
If the culprit is the current why is it possible to charge my other batteries which are 2300mA with the 1200mA charger?
qap15 is offline
Old 02-27-2011 | 02:44 PM
2300mah versus 4500mah has little to do with charging besides time - if the 4500 is the same cell count, it would just take longer. So you're charging with a 12v adapter that puts out 1200ma - that's just 1.2amps.
Are your 2300s 8cell packs? If they are, then your adapter should be able to charge them it'll just take more than 2x as long.
This would power it -
http://www.amainhobbies.com/product_...-138V-10A-130W
Duster_360 is offline
