throttle servo question >
Old 02-25-2011 | 10:16 PM
Default throttle servo question
hi all
i'm unsure wheather this is normal or not, but, my throttle servo is either going wide open or nothing with no inbetween. i try to lightly squeeze the trigger and it just jumps straight to wot. even tried it with the car running (under load) for the same result. radio is spektrum dx3.0, servo is savox 1258tg and reciever battery is 2 cell life. steering servo works fine(1256tg) tried all settings on radio gear. what am i missing?
any help would be appreciated thanks
matto1973 is offline
Old 02-25-2011 | 10:33 PM
Wild guess, make sure the throttle exponential isn’t jacked up (or down, whichever). Should start with it at 0% (or LN for linear).
What happens on the brake side?
Dave H is offline
Old 02-25-2011 | 10:51 PM
exponential set at 0 and doesn't matter which setting still the same brake side aswell. maybe too much voltage from battery?
Old 02-26-2011 | 04:53 PM
Have you tried switching the servo plugs for a test??
Dave H is offline
Old 02-26-2011 | 10:27 PM
good man
i'd of never thought of that. just swapped them over and hey presto the steering servo is now doing it. time for a new reciever you think?. i've been wanting to buy futaba 4pks radio gear or airtronics m11x. might be time to upgrade. thank you for your help. where would we be without the internet.
thanks again
Old 02-26-2011 | 11:17 PM
hang on, i've just tried it with another identical reciever and it's still happening. has to be the servo?
