TEAM POWERS NEW PLUTONIUM MOTORS
#601
On mine I just max the timing and gear to temp, mine is fast, faster then my 13.5 D41s ever was. I also run the higher torque rotor.
#602
Have you tried the advance endbell ?
#603
The one I use is a 12.5mm one TP-BLR-TP125G-RV1
My 13.5 Actinium came with the 12.3mm Rotor.
#606
Actinium motors don't ship with 12.3 rotors only 12.5. Both 12.3 and TP-BLR-TP125G-RV1 are not roar approved.
#607
Well mine that I picked up in HK came with a 12.3mm rotor. The first run ones seem to have both the 12.3 and the 12.5mm rotors. I had mine 3 weeks before it was ROAR approved. As for the Rotor I use, I never said it was ROAR approved I said I used it.
According to the ROAR list only the the TP-BLR-TP125G is ROAR Legal, not the -R variant.
#608
TP-BLR-TP123G-R 12.3mm x7.25mm x 24mm - ROAR (Plutonium only)
TP-BLR-TP123G-S 12.3mm x5mm x24mm - Stock Spec Rotor
TP-BLR-TP124G 12.4mm x5mm x24mm
TP-BLR-TP125G 12.5mm x5mm x24mm
TP-BLR-TP125G-R 12.5mm x7.25mm - ROAR (actinium or plutonium)
TP-BLR-TP125G-RV1 12.5mm x7.25mm x 25mm
TP-BLR-TP127G 12.7mm x5mmx24mm
TP-BLR-TP130G 13.0mm x5mmx24mm
#609
Have you actually measured them? Every single one I ever measured (about a dozen) has been between 12.38 and 12.41mm. That's why I eventually sold all mine and went to something else. I couldn't find any big and strong rotors.
#610
-James Davenport
#612
Mine don't have a temp sensor - only knock I have to say about the motor.
#614
