TEAM POWERS NEW PLUTONIUM MOTORS >
Old 06-28-2014, 06:57 PM
  #271
DesertRat's Avatar
Two problems:
One, when my motor arrived the hall effect sensor board was mounted incorrectly such that one of the sensors was twice as far from the rotor as the others and had to be fixed before the motor would run without my ESC throwing an error... no big deal for me as I am a seasoned veteran with a soldering iron but this might have taken a lot out of someone else, so look out for that Team Powers.
And
Is it normal for there to be a little hesitation on the bottom end at full advanced timing? Is this motor not idiot-proof like most motors?
DesertRat is offline
Old 06-28-2014, 07:22 PM
  #272
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Hi Evan - my 17.5 is pretty odd sounding at the bottom end until I'm rolling... After that, no issues are observed. Motor is super fast..
hanulec is offline
Old 06-28-2014, 07:27 PM
  #273
DesertRat's Avatar
Thanks Hanulec, I won't worry about it. The motor spools up really strong but I was just concerned about the zero-rpm start in my 1/12 scale. If it runs well I'll run it in Vegas.
Old 06-29-2014, 02:22 PM
  #274
MeBeMikey's Avatar
Default Team Powers 13.5 Actinium
I just received my 13.5 Actinium motor from "team-powers.co.uk".
Looking forwards to finding is blinky sweet spot and boosted spot over next month.
Very cool to hear great news about this motor over in the USA. I just might be changing all my cars and buggies over to Actinium motors!
MeBeMikey is offline
Old 06-29-2014, 02:31 PM
  #275
erchn's Avatar
At the Reedy race, in blinky, they were gearing the 13.5 at a 5.4 final...and they were very fast.
erchn is offline
  #276
b20btec's Avatar
Any plans for roar approval for the 21.5 with a 12.5 rotor? Can't run this in usgt events because it's considered to be a tuning rotor. Referring to the actinium.
b20btec is offline
Old 06-30-2014, 01:21 AM
  #277
MeBeMikey's Avatar
Thanks for the info. I'm racing outdoors on a large track. I was going to start at 4.0 with "0" timing. I need to look at that track to compare size.
Old 06-30-2014, 03:59 AM
  #278
erchn's Avatar
I believe Tamiya is about 130' straightaway. Every setup I've seen is max timing, and I know the motors are efficient and like higher RPMs, so I think 4.0 is probably gonna be a little low. But please do report back your findings.
erchn is offline
Old 06-30-2014, 09:04 AM
  #279
Trader Rating: 19 (100%+)
Hello all,
The 21.5 will be ROAR legal soon. It was not submitted at the same time as our 17.5, `13.5 and mod motors. This was an oversight on my part. The 21.5 is being submitted to ROAR (in transit) and will go through their testing criteria. I have no doubt it will pass.
The 21.5 will be submitted with the 12.5 rotor.
Desert Rat,
Please PM me your address and I will send you another sensor board. Thanks.
MeBeMikey,
Please run your motor at max timing. The Reedy track is about 100' long. Hope that helps.
Art
Advil is offline
Old 06-30-2014, 09:33 AM
  #280
Trader Rating: 14 (100%+)
What's the latest on ETA for 13.5 motors?
va.racer is offline
Old 06-30-2014, 09:34 AM
  #281
Absolutely fabulous motor. Had a chance to run this thing (21.5) this weekend and it is wicked fast and runs about 165 at max timing at a 3.6 FDR. The only thing that hung me up a little bit was installing it into my TC6.2. The rotors flat cut wasn't quite deep enough and I had to take a dremel to it to make it a little bit longer towards the motor. Needed about 1/8th of an inch more to get the pinion (CRC 53T) to line up correctly on the spur (Kimbrough 96T). I am very impressed with the low end and the top end on this thing. Thought my damn tires were gonna spin off the rims
Carnage9270 is offline
Old 06-30-2014, 09:36 AM
  #282
Gridworks Racing's Avatar
We have them in stock.
Gridworks Racing is offline
Old 06-30-2014, 09:39 AM
  #283
Off topic a tad, but A+ on ordering from Gridworks. He's not kidding about the service...he takes it personal.
Old 06-30-2014, 09:47 AM
  #284
Yes, these motors may require slightly different gearing than some of the others, but once you find it, they are very fast and seem to never stop accelerating.
Thank you Mike. Glad we were able to take care of you. Thanks again!
Old 06-30-2014, 11:04 AM
  #285
DesertRat's Avatar
Originally Posted by Advil
Desert Rat,
MeBeMikey,
Art
Thanks Art, I really appreciate it.
