castle sct sidewinder >
Old 02-22-2011 | 10:26 PM
Default castle sct sidewinder
so i bought the sidewinder sct system two weeks ago and on the first day the esc had a glitch and stopped working and i just got my new one from castle and within the first 20 minutes the motor shaft snapped and then i plugged in my spare castle motor and ten minutes later the esc got real hot and went up in a puff of smoke, this happen to anyone else on here or am i just unlucky, either way it looks like another 2-3 weeks to wait for another motor/esc.
austincoru is offline
Old 02-22-2011 | 10:42 PM
Tell us more about your setup
What car ?
What batteries ?
What speed did you have the car geared for ?
Cheers
crusey_aus is offline
Old 02-22-2011 | 10:45 PM
i was running it in a sc10, with the gens ace 5000mah 40c 2s batts, it was geared at 17/87
Old 02-23-2011 | 01:07 PM
Perhaps just bad luck. I had a similar streak of bad luck with 1/8th esc's a while back. Since you mentioned a motor shaft snapping I would suggest taking a look at your drive train. In general Castle motors are known to be very durable.
kcobra is offline
Old 02-23-2011 | 03:37 PM
chances of there being a problem with your setup/car is about 99%
gear mesh, something binding in tranny, bearings in tranny or hubs are seizing.. something..
2 esc's and a broken motor shaft SPELL a problem with your car or mesh way to tight.
3 sidewinder sct systems, with lots of use on all of them and no failures to date..
racerx711 is offline
Old 02-23-2011 | 05:27 PM
Agree, need to check the drivetrain, it should roll freely with pinion removed. If it doesn't, something's binding.
Duster_360 is offline
