iCharger and power supply >
Old 02-18-2011 | 09:09 PM
Default iCharger and power supply
I want to charge 25C 4000mAh Lipo batteries at a 5C rate.
That means I need a charger capable of 20 amp charge current.
This charger can do that...
http://www.hobbyking.com/hobbyking/s...dProduct=10382
Also, it needs a power supply that is rated above 360 Watts...
BUT, if I only plan to charge the battery mentioned above(one at a time), I will only use around 170 Watts. In other words, the charger wont be demanding more than 170 Watts. Therefore, I wont need a high watt power supply if my charger isnt demanding that much watts.
So do i need a power supply that is rated at 210 Watts? or 360 Watts?
This PS is rated at 350 Watts. Could i squeeze by with it?
http://www.progressiverc.com/index.p...emart&Itemid=1
Thanks for your input!
looklikeaflip is offline
Old 02-18-2011 | 09:21 PM
Yes that power supply will do the job
Cheers
crusey_aus is offline
Old 02-18-2011 | 09:31 PM
Agree, that power supply is a good match for the charger, has a good rep too.
To elaborate you are correct in thinking you could get by with about 210W for now, but with the 350W you are set for whatever you might do in the future with the charger. The slightly higher voltage compared to a typical supply is a good match for that charger too if I'm not mistaken.
Dave H is offline
Old 02-18-2011 | 09:42 PM
Awesome! Thanks guys..
Old 02-19-2011 | 12:54 AM
RC MARKET's Avatar
http://rcmarket.com.hk/index.php?cPath=53
RC MARKET is offline
Old 02-19-2011 | 01:13 AM
Did anyone ask for a spam link ?
http://www.himodel.com/search.php?psearch=icharger
http://www.himodel.com/search.php?psearch=23a
www.hobbyking.com
www.epbuddy.com
Cheers
Old 02-19-2011 | 01:24 AM
Not sure where you are located, but same price after shipping from here in the US:
http://epbuddy.com/index.php?main_pa...&products_id=3
http://www.amainhobbies.com/product_...er-6S-20A-300W
silentbob343 is offline
Old 02-19-2011 | 05:53 AM
Originally Posted by RC MARKET
Your price a bit high compared to HobbyKing...
ganymede is offline
Old 02-19-2011 | 09:01 AM
If you buy your iCharger from HK, just be aware that any probs will be expensive since you have to pay to return it (and wait) and get any probs resolved. Not knowing where you're located makes this less than clear cut.
My 3010b iCharger and Powerlog were bought from Progressive RC and I know he provides top notch after the sales service for anything he sells.
Duster_360 is offline
Old 02-19-2011 | 09:34 AM
I live in So Cal.
Old 02-19-2011 | 06:06 PM
I wouldn't buy one from HobbyKing in Hong Kong, either buy from Progressive RC, EPBuddy or get the same thing from AMain (the re-badged Protek chargers) and eliminate any probs with returns. With S&H, it'll be cheaper to get one from an iCharger delaler in the US.
I've read some nightmare stories on returning iChargers thru HK.
Old 02-19-2011 | 06:53 PM
+1!
ganymede is offline
Old 02-19-2011 | 07:36 PM
Thanks for letting me know. Canceled order. Newb mistake. hahahhah
Old 02-19-2011 | 07:54 PM
Do you guys have a link for Cheap Turnigy Nano tech batteries?
Old 02-19-2011 | 09:11 PM
I have purchased both my Ichargers from HK, dont really see an issue with it
You can only buy Nanos from HK unless you want to pay marked up priced on ebay
Cheers
