-   -   Is there something Wrong with my LIPO? (https://www.rctech.net/forum/radio-electronics/476369-there-something-wrong-my-lipo.html)
TERRA NOVA 01-28-2011 10:21 PM
1 Attachment(s)
Take a look at this. I am new to LIPO batteries, I have run Nitro for 10 years. I had this battery in my Losi Strike and it discharged below safe voltage. I forced it to charge up and it started to swell. I stopped the charge and laid it on the shelf. This is what I found 2 days later.
bomber9 01-28-2011 10:45 PM
your battery is toasted!! soak it in salt water for a day or so just to make sure it dont blow up then get rid of it. make sure you dont keep that battery indoors.
RCaddict0 01-28-2011 10:52 PM
Naww...Thats how its supposed to look! :lol:
TERRA NOVA 01-28-2011 10:58 PM
That's what I thought. Some good ol duct tape should hold it together.:smile:
racer1812 01-28-2011 11:56 PM
I thought that's how all the Zippy packs came? You mean that's not normal:lol:
I know it's not a zippy:p
Duster_360 01-29-2011 09:05 AM
Looks like you were lucky it didn't vent. Obviously, when you 'force' a low voltage lipo to charge, you're supposed to watch for swelling (typically called puffing) and immed stop at any point along the charge (the forced part or the lipo part) if you see if start to swell. Then take it outside somewhere it can't do any damage of it does indeed go ahead and vent/smoke.
From where you are now, it's time to dispose of this one. Harvest the connectors and use a auto 1157 tail light bulb to discharge it to zero volts outside. After 24hr or so, remove the bult, twist the wires together and toss it.
You should be using a lvc (low voltage cutoff) so this can't happen....
TERRA NOVA 01-29-2011 09:47 AM
I did watch for swelling. With the hard case I probably didn't notice it early enough. The LiPo has already been safely disposed of. The ESC was set for Lipo cut off, but its obvious it didn't work.
Duster_360 01-29-2011 10:56 AM
Unfortunate the lvc cost you a lipo. After you get used to running lipo, you should be able to see when a lipo 1st starts to slow a little. Thats where I usually stop and re-charge mine.
You can get a low voltage alarm type warning device, but its something you have to watch as it doesn't pulse or cut power like a esc based lvc does.
TERRA NOVA 01-29-2011 11:05 AM
Oh Well! I had a dozen more Lipos on the shelf anyway. I don't plan to get too used to running big Lipo Power, I am still a Nitro fan. I am running Lipo for the RX in my Nitro Truggy now. Dynamite makes a LVC and regulator in one unit. Should save me from ruining another lipo. I also have a nice Dynamite LiPo Cell voltage checker which works awesome.
