How to charge AAA nimh? >
Old 01-21-2011 | 10:29 AM
  #16
Thanks.....there you go.....
Duster_360 is offline
Old 01-05-2012 | 01:04 AM
  #17
91420l's Avatar
Sorry to post for a old thread.
I need your help to understand how to charge AA and AAA with my charger.
My question it self may not be making sense...
I searched quite bit but never had any good clue.
Thanks in advance.
Charger: Venom Pro Charger
Batteries: AAA = Energizer 850mah 1.2V / AA = Energizer 2300mah 1.2V
My understanding: To Charge 4 AA or AAA in series
For AAA:
(850x4)=3400
3.4 x 0.2C = 0.68a = Charge Amp
End Voltage = 1.2 x 4 = 4.8
For AAA:
(2300x4)=9200
9.2 x 0.2C = 1.84a = Charge Amp
91420l is offline
Old 01-05-2012 | 01:20 AM
  #18
Not quite right mate
You dont add capacity in series, it stays the same regardless of the number of cells
850 mah AAA
1c charge rate will be 0.85 amps
1/5c charge rate will be 0.17 amps
2300mah AA
1c charge rate will be 2.3 amps
1/5c charge rate will be 0.46 amps
A nimh cell will peak at around 1.45v
4 cells in series will peak at around 5.8v
Cheers
crusey_aus is offline
Old 01-05-2012 | 09:09 AM
  #19
91420l's Avatar
I see!
Thanks for your advice!
91420l is offline
Old 01-05-2012 | 09:19 PM
  #20
91420l's Avatar
One more quick question.
is 1/5C charge adequate for these Enagizer NiMh AA and AAAs?
I use AA for RC contoroler(Spektram DX2X) and AAA for Kyosho MIniZ.
91420l is offline
Old 01-05-2012 | 09:54 PM
  #21
Depends on the charger you are using
If you use a dedicated slot / cell charger you can use higher rates
Most will handle up to a 1/2c charge rate
The lower the rate the better for the batteries
1/5c will be fine
If you want decent Nimh cells grab yourself some Sanyo Eneloop LSD (Low Self Discharge)
Cheers
Old 01-05-2012 | 10:23 PM
  #22
91420l's Avatar
Thank you again!!!
91420l is offline
Old 06-03-2013 | 09:39 AM
  #23
Angry_Arowana's Avatar
I don't know if anyone are actually gona read this but,when I'm using my venom pro plus charger on the eneloops,why does it get full at around 1000mah while charged at 0.2-0.3 amp ?
I have got a proper aaa battery tray with the proper dean plug soldered to to join my lipo charger.
What am I doing wrong ? Or is this normal ?
Angry_Arowana is offline
Old 06-03-2013 | 03:30 PM
  #24
Are they triple A? I think those are rated at 750 min - 800 typical? If so, since some charge on a nimh will go off into heat, 1000 sounds reasonable, good even. How warm did the cells get?
Dave H is offline
