LRP SXX StockSpec V2 ESC
#947
Does anyone know what the difference is between the Lrp x12 torque timing settings and the "other motors" setting?
Is there a performance increase using x12 torque timing on another motor(reedy sonic) ?
Also, with the "other motors" settings, what does a higher value do to the performance of the motor ? The setting is said to change initial drive level, what exactly is this ?
I'll take a stab at it
I believe the LRP X-12 settings have a mild, slower slope on the ramp up
This setting will seem slow with "other" motors, but it will keep temps low, and work in perfect harmony with the X-12 motors, as it is a more custom mapping for LRP motors specifically
#949
I have a LRP TC Spec V2 speedo would a Savox SC-1251MG servo trash the BEC on the speedo? If so what would be a cheaper alternative?
#950
It probably would. The guys at LRP on their forum said that there is a connection between BEC failure and savox servos. I had a savox servo that i bought for $75-80 and when i bought the LRP speedy i bought a sanwa/airtronics servo for $100 and i have had no problems at all. Guys at my track have had their BECs fail and they use savox type servos.
#951
I was running a Futaba BLS651 servo in my WGT with the same ESC (SXX V2 Stock spec) and my ESC also died. Mind you, mine died after 2 months where the other guy's ESC would die the same day. I think that everyone from our track that has had this ESC has fried them. At this point, the failure rate is pretty high and the servo brand hasn't really been a factor.
#952
One of our guys at the track was running a Savox servo and blew 4 of these LRP SXX V2 ESCs (2 TC spec and 2 stock spec). His ESCs didn't last a week. One of his fried after 2 heats and he replaced it with a spare and cooked that one during warmup for the main in the same race! The other two fried when he was putting his car together and configuring his endpoints, etc.
#955
I have had 3 Stock Specs in and out of my pan cars and all of them have been fantastic... granted, the latest one only has 2 weekends on it. Using the JR 3650 in all my 12ths and WGT. No issues as of yet.
I ran one of the Stock Specs briefly in a Sedan w/ the Futaba 9452 and it held up great, as well.
Interesting to hear about the BEC failure rate with Savox....
#956
I sent my SXX V2 back about a week ago, Put it in the car, did the basic set up, ran it for 10 mins... all was well, went to make a change, dial in some drag break and once i got out of the menu, it stopped working! It was only 4 days old. not a happy camper. I have used LRP only for years and never had an issue, even my chargers are LRP.. I hope they get it together.
#958
